My son's car makes a click sound sometimes when accelerating, not sure if it's the axel.. we jacked the rear up and turn the wheel, not sure if this noise is normal.
https://youtu.be/zPafgX9Nhh4
My son's car makes a click sound sometimes when accelerating, not sure if it's the axel.. we jacked the rear up and turn the wheel, not sure if this noise is normal. https://youtu.be/zPafgX9Nhh4
The noise in the video is normal. That's just lash in the geartrain.
The click while accelerating could be relative motion between the hub and the half-shaft splines. It happens when you make enough torque to overcome the thrust of the axle nuts. If that's what you're hearing, you'll also have a click when you suddenly lift off the gas and the torque reverses.
Most people address the noise by chasing it with more nut torque, followed by Loctite, etc. I don't like those solutions. I prefer lubricating the splines and the thrust surface on the back of the hub. There are lots of forum conversations about this.
