Brake Education needed
Old Oct 24, 2022 | 08:04 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Brake Education needed
When looking for new rotors for my 2001 C5, the advertisements indicate C5/C6 are the same item.
1. are they the same thickness, offset and diameters?
2. is there a larger diameter rotor for say Z06? Z51?
3. Will C6 calipers bolt onto a C5?
4. Do larger rotors require different calipers?
5. What mix n match combos yield better braking performance?
Lost in America, point me the way!!!!
Old Oct 24, 2022 | 09:23 PM
Iceaxe's Avatar
Iceaxe
You would probably have much better luck asking this in the C5 section. I can answer all your question in regards to the C6, but I have no clue which brakes if any are interchangeable between the C6 and C5.
The short answer with regards to the C6 is base, Z51, GS and Z06 have different brakes.
Old Oct 25, 2022 | 01:02 AM
coupeguy2001
Default Brakes
Thx
Old Oct 25, 2022 | 10:37 AM
Corvette_Dez's Avatar
Corvette_Dez
1. C5 standard rear rotor are the same as C6 standard rear rotors, but the front are different.
2. C6 Z51 rotors are larger diameter and cross drilled. The calipers are different for the Z51 package as well.
4. As a general note larger calipers are required for larger rotors.
5. I would suggest a Performance brake package from powerstop if you're looking for a good balance of price and improved braking.
Old Nov 14, 2022 | 06:29 PM
INFERNO GS's Avatar
INFERNO GS
Default brake question
ALL C5 brakes are the same.
ALL base C6 rotors and pads are the same as the C5.
Stock C6 big brake calipers (GS and Z06) will bolt on to the front. You will no longer use the C5 brake bracket because the caliper now bolts direct.You will need the larger rotor and 18" wheels to clear the larger caliper.
But don't take my word for it. Check out KNS brakes. All they do is brakes and they are great to deal with.
Old Nov 20, 2022 | 07:51 PM
hubes's Avatar
hubes
C5 guys use C6 front calipers because they're less likely to spread
To Brake Education needed
