C6 GS - lacklustre performance when driving normally.
Old Nov 25, 2022 | 05:25 AM
KPrich's Avatar
KPrich
8th Gear
Really appreciate all the comments! Got it check out at the garage and they told me everything is normal which is a relief. Time to book it in for a ECM tune…
Excellent forum this one!
Cheers folks!
Old Nov 25, 2022 | 06:04 AM
jonjoy's Avatar
jonjoy
You buy a world class sports car with an automatic. Maybe your just a lackluster driver?
Old Nov 25, 2022 | 07:23 AM
Raffman55's Avatar
Raffman55
2024 C6 of the Year Finalist - Modified
2018 C1 of Year Finalist
2.73 rear gears. Standing start is going to suck !
Old Nov 30, 2022 | 11:38 AM
PCMusicGuy's Avatar
PCMusicGuy
Even the 2.56 gears work fine for launching. The feel of these cars are all to do with the throttle response, which isn't great in stock trim. The easiest solution is a throttle controller which doesn't require you to touch the ECU. Otherwise, I don't think there is anything you can do with a throttle controller that you cannot tune into the ECU, but that takes experience and know how and is generally a lot more expensive than a throttle controller.
Old Nov 30, 2022 | 02:13 PM
fast08408's Avatar
fast08408
5th Gear
Most likely in the tune, a tune wakes up an A6 car drastically if the tuner has any idea of what he is doing. Mine felt like a completely different car after the tune.
