Should I Switch to a Stroker
The upside is that it's easier to upgrade your power level if you're starting with more cubic inches.
More Displacement = More Torque
Con's
Higher Piston Speeds at any Given RPM
Higher Rod / Piston Acceleration at any Given RPM = Higher Loads on Components
Increase in Compression Ratio (may be a Good Thing or a Bad Thing - depending)
Components (Crank, Rods & Pistons) Will Probably be More Expensive than Comparable Components for Stock Displacement
Machine Work May be Required on Block (to provide clearance for stroker crank / rods.
So - if you go that route - make sure not to skimp on the Rotating Assembly components (Crank, Rods & Pistons), and especially not on the Rod Bolts.
And old motorhead is correct - to take full advantage of the longer stroke - the heads need to be able to flow enough to support the extra displacement.
too.
too.
That said, displacement is meaningless with the right forced induction. How much power does a 2L engine make with a 500hp turbo? 500hp. How much power does a 7L engine make with a 500hp turbo? 500hp. Displacement is not a factor with the correct drivetrain setup per application details. In other words adding displacement to gain power is an potentially extremely unreliable means of gaining power. But I digress
What I am saying is beware of rebuilding any engine. Statistical analysis t-test may show a P value much less than .005 (<< .05) for population distribution > 1,000,000 sample size, that for factory Chevrolet engines made between 2002 and 2012, and Toyota/Nissan engines made between 1992-2002, it is extremely rare (P << .05) for a rebuilt engine to reach 200,000 miles whereas it is extremely common for factory versions of those engines to reach 200k and beyond.
Doesn't matter imo which motor "lasts" longer-the OP's motor is shot lol despite it not being rebuilt, it happens.
If it were me I'd look for a reputable builder to build something or look to get a new shortblock and have upgraded heads and cam-turn a negative into a positive. jmo
2. Longer stroke has some issues in and of itself which have been mentioned I think. From engineering perspective, the forces and stresses involves with longer stroke can become significant at high RPM making it undesirable in performance applications. It isn't about displacement it is about stress and details associated with the angles made which may have long term consequences, such as piston 'side loading' or piston rocking, and the depth of piston in the bore, and some things we don't even realize by inspection, it may take a computer model of the exact engine and stroke to see all of the potential abuse.
You can skip all this issues by simply using a previously reliable engine with 100k miles or whatever and just taking it another 10-20 years. They are low cost, generally, my 5.3L for example was free. And there is no down time, no waiting for machine work. You can swap in a day. Be driving tomorrow.
Taking into consideration what you're saying-perhaps going to a 3.9 stroke instead of 4.0 would be a better choice for an LS2.
If it were me and I had to pay for tear down and install etc-I'd prefer to put in something with more punch.
Your way of thinking, the OP would have to pay good amount of money to get exactly what he had before.
My thinking is the OP, having to spend the labor/parts money already, may as well pay little more and get more horses and torque.
Its not some secret, I will tell you now: The primary character of well cared for engines with high mileage is
1. Intact OEM pcv hardware, no catch can or modded hoses/breathers
2. Original air filter and air tracts, no cold air intakes or aftermarket filters
3. Crankcase staining features of quality synthetic routine maintenance "light gold brown" with no texture from deposits/conglomerates
4. Under valve cover reservoirs of oil are dark but not sludged or sticky
5. No crust formation around fringes of operating oil level washing areas which indicates contaminated oil flow through for extended periods
6. Even compression test across all cylinders, doesn't have to be high, just even
7. Color of gaskets, silicone if any, is OEM indicating never-before-removed covers and seals
8. Factory harness, OEM tapes & ties, look for unripped plastic insert 'buttons' that hold wiring down which has never been removed
9. Absolutely no modification to the engine
10. No evidence of pressure washing or heavy degreasing on behalf of the salvage yard or engine sales
11. Never buy from a personal seller, only seek used engines from salvage yards which have hundreds of engines to sell of all kinds
Its also good if the Engine is from a crashed vehicle (or some evidence of a wreck) with a bit of broken glass or smashed plastics (reason for removal)
Theres more but this is most of it. If you follow these it is high chance of success.
In 2017 I went to a yard and looked at 10x 5.3L engines. I compression tested all of them and the best one was the most filthy, highest mileage engine they had. They gave it to me free, couldn't believe that was the one I wanted. Since then I put 50,000 miles on it 600rwhp over 5 years daily driving.
Not everybody can do what I know how to do. But it isn't impossible either. I am not here telling people what to do: Only revealing the possibility, adventure, ideology, ambition, affect to get what you want and not have to worry or pay a lot of money or spend a lot of downtime waiting on other people and trusting other people only to be let down.
You get more when you pay less by using knowledge because knowledge really is power.
And then.......
