Alternative for 20w50
Old Dec 3, 2022 | 04:29 PM
fast08408's Avatar
fast08408
5th Gear
Run what your engine builder tells you to, every built engine I have had built the builder recommended running VR1 20W-50. You are not running a stock engine with factory clearences. 80 psi of oil pressure is fine for a built engine and as long as you have a way to vent crankcase pressure the seals will be fine.
