Anyone using BTR rocker arms?
Old Dec 26, 2022 | 12:09 PM
Jerms1456's Avatar
Jerms1456
Default Anyone using BTR rocker arms?
Anyone using these? https://briantooleyracing.com/btr-ls1-ls2-ls6-bare-rocker-arm-rkr-ls-1-7e.html allegedly they are 1.7's drop in. Ordered their v2 trunion kit, car is stock but plan on dropping in a 228/232 112lsa cam with just north of 600 lift.
Simply getting ready for that install, will not consider 1.8 rockers. Has anyone had issues with stock rocker tips? I assume that after so much lift the stock rocker would have geometry issues? It's a BTR product so I'm assuming it's good.
Old Dec 26, 2022 | 05:32 PM
jamieo's Avatar
jamieo
I would call BTR and see what they say.He told me my stock low-mileage arms would be fine with my setup.Running his stage 2 LS3 cam and trunnion upgrade.He doesn't upsell anything and will give you an honest answer.
Old Dec 26, 2022 | 05:50 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Any reason you don't want 1.8 ratio rocker arms ...
1.8 ratio rocker arms will increase both your intake and exhaust valve lift about .030"
Comp Cams make a very high quality full roller 1.8 ratio rocker arm that fits both the LS2 and LS3.
Attachment 48331316
Old Dec 26, 2022 | 06:31 PM
Turbo6TA's Avatar
Turbo6TA
BTW ... BTR sells quality parts, but the problem with solid trunnions is that they all wear out over time.
On the other hand, the problem with the OEM needle trunnion bearings is that they have a tendency to fall out ... The needle trunnion bearings in the Comp Cams roller rocker arms will not fall out.
Old Dec 26, 2022 | 06:45 PM
Jerms1456's Avatar
Jerms1456
I have seen issues created with aftermarket cams with something as aggressive as the 1.8's. Usually its from the aggressive ramp up. Im sure it is fine with most builds, just not a route I want to go down. I'm ok with missing out on 7-10 hp. Was honestly not considering changing rocker arms at all until I saw BTR makes a different style. Was curious if anyone was seeing issues with stockers that make the BTR's make sense. My plan was to go with the v2 btr's which are supposed to be needled bearing trunions with oil supply holes. They are also supposedly encapsulated in the bearing race.
Old Dec 26, 2022 | 06:57 PM
Turbo6TA's Avatar
Turbo6TA
Install want you want .. it's your engine.
For the last 2 years, I have been running a Cam Motion camshaft in my supercharged GS along with 1.8 ratio rocker arms with no problems.
Actually, there is nothing wrong with the OEM rocker arms (as long as the needle bearings don't fall out) ... it's just kind of a crap shoot if the OEM needle bearings will remain in the rocker arms like they are supposed to.
Sounds like the BTR rocker arms you mentioned are basically designed the same as the Comp Cams rocker arms I have except they are of the standard 1.7 ratio.
Sounds like it might be a good choice.
To Anyone using BTR rocker arms?
