C6 ls2 cam swap
I've built couple cars but would never change a cam on my own Lol.
I would image having to remove the rockers, pushrods and lifter trays before rotating the cam and of course removing it.
Close. Lifter trays stay in place. OP should watch some youtube videos before going farther. Mostly to see how to keep lifters from dropping into the motor when the cam comes out.
Correct. If a lifter dropped the pushrod would also drop. The dowel rods pretty much eliminate the possibility. Sounds like you are doing everything needed to get the job done.
To change the valve lifter preload on the LS engines, you change the length of the pushrod ... a longer pushrod gives you more lifter preload and a shorter pushrod gets you less lifter preload.
