RCDLR programming issues
Old Jan 17, 2023 | 03:23 PM
chanchett72's Avatar
chanchett72
Cruising
Default RCDLR programming issues
***This is a re-post. Moving from General to Tech forum***
Hi! I have a C6 2007 base model with a bad RCDLR module and having a hard time re-flashing the firmware. I was hoping that there was someone in the St Louis area that has encounter this issue and would be willing to help out. I have read as may forums that I can find on this subject and have the TECH 2 scanner and software, but keep running into roadblocks. Hopefully I am missing something simple or not following the procedure as I should. Any help would be welcome. Thanks in advance.
