Drivability with ported MSD without tuning
Old Jan 26, 2023 | 08:06 PM
projekt's Avatar
projekt
7th Gear
Default Drivability with ported MSD without tuning
Did some searching (sorry if its been covered) on the matter but couldnt find anything definitive... I have a tune scheduled for the coming month and I would like to go ahead and add the intake manifold just before I drive it to the shop which is 60 miles away, safe to do so? Its been tuned once before to compensate for the cam. I have the NW 103 tb to go on as well but I was going to put in on once I arrived to the shop just to err on the end of caution. Thanks in advance
Old Jan 27, 2023 | 04:01 AM
Sub8's Avatar
Sub8
It will run fine with manifold fitted, maybe stay away from wide-open.
Apparently the NW103 also does not require any specific tuning around min airflow / idle area, so that would probably be ok to fit as well.
Old Jan 30, 2023 | 11:28 PM
projekt's Avatar
projekt
7th Gear
Thanks so much for the response especially since i posted this in the wrong section... opps. Yes Ive read the 103 has the same/similar scalar at idle/ or just off idle but wasnt sure that would be ok. I definitely dont plan on doing any romping on it to get it there.
Old Jan 31, 2023 | 08:03 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Tuner in Tampa
You shouldn't have anything to worry about.
Old Jan 31, 2023 | 09:09 PM
grubinski's Avatar
grubinski
If your tuner is like most tuners, if there is a driveability issue, they won’t fix it on the dyno. Driveability is much harder to get right than power/engine safety. The tuner can make sure that you won’t hurt your new engine, but driveability may come down to you buying HP Tuners and fixing it yourself.
Old Jan 31, 2023 | 09:19 PM
airbrush1's Avatar
airbrush1
I think his major concern wasn’t the cars street manners after the install pre-tune, but safety. You’d hate to have a bucking and stalling issue on a drive that long, not to mention the safety of the motor itself.
Old Feb 1, 2023 | 04:50 AM
Sub8's Avatar
Sub8
The drive issues usually come with a CAM swap, not really manifold or throttle.
Old Feb 1, 2023 | 10:20 AM
drewz06's Avatar
drewz06
thing knower
its just me but i'd pay for a lift on a flat bed over to the shop.... all that money, would suck to have something happen half way through the trip then be scrambling to figure out a solution on the side of the highway with 4,000 lb wrecking ***** flying past you at 70 mph...
it shouldn't hurt anything but shouldn't isn't a guarantee...
To Drivability with ported MSD without tuning
