overdrive balancer
Old Feb 3, 2023 | 12:19 PM
Kevin Mason's Avatar
Kevin Mason
Default overdrive balancer
Did a brief search and didn't see this question asked or answered, so here goes:
What does an overdrive balancer do and why wouldn't you want to underdrive the power steering, a/c and other useless stuff? The water pump you wouldn't want to underdrive, but all the other junk?
Explain to me, please.
Old Feb 3, 2023 | 02:53 PM
davidfarmer's Avatar
davidfarmer
I've never seen an overdrive pulley. We underdrive everything for track cars...the sustained high RPM makes up for the lower ratio compared to street usage. Small aluminum damper and smaller 5" clutch shown
Old Feb 3, 2023 | 07:41 PM
old motorhead's Avatar
old motorhead
About the only reason you'd want an overdriven crank pulley is to spin a blower faster. I'd opt for an underdriven crank pulley to spin all of the accessories slower to save a few HP on anything naturally aspirated. Usually, you up the idle speed a bit when you add a bigger cam. If you do that, you won't overheat or undercharge at idle. Once you get above idle speed, it's a moot point. Not much downside to an underdriven crank pulley if you're naturally aspirated.
Old Feb 4, 2023 | 11:23 AM
Kevin Mason
So the overdrive pulleys people mention are actually underdrive?
Thst would make sense.
Old Feb 4, 2023 | 12:12 PM
old motorhead
There are three types of crank pulleys. Stock diameter available OEM or aftermarket. Overdriven (larger diameter) available from the aftermarket. Underdriven (smaller diameter) available from the aftermarket. Folks with belt driven superchargers are about the only ones running the overdriven crank pullies. Those with exhaust driven superchargers (turbos) and those naturally aspirated can benefit from an underdriven crank pulley.
To overdrive balancer
