No Crank No Start
I had an issue with it not cranking or starting on a few occasions in the past year of ownership, so aggravating.
It is not cranking or starting, nothing. all the lights work, dash, stereo, etc.
I replaced the starter relay already, checked every fuse, the grounds all seem good. Battery cables secured tightly, no corrosion.
Last time I had this issue, I brought the battery back to Walmart for testing (about a month after purchase), tested fine.
Before I put the battery on a charger, it read 12.5 V, I have had it on a charger for about 5-6 hours, reading 12.5 V. I do recall in the car, the gauge would read something like 14V on the dial, which it is not now.
I am so frustrated, thinking of just rid of this car.
Can anyone please help with advice? This is my daily driver, and luckily I work from home, but am stuck.
battery off the charger is 12.8v
battery connected, pin 6 above reads 1.36 v
pin 14 reads 1.36v . I did it again they both read 1.28v that time.
battery disconnected, between pins 6 and 14 is reading 95.3 ohms
what is this telling you?
and thank you very much!
https://youtu.be/JicbzR3Juh0
Yes, battery connected, pin 6 red lead Voltage on meter, black lead to a non painted bolt in the driver footwell for ground, I get 1.36 V, same for pin 14 red lead on meter, black to same bolt.
Battery unhooked, set to ohm on meter, red lead on either pin 6 or 14, with black lead on either pin 14 or 6 yeilds the readings above.
What is that saying?
I hooked the battery negative terminal back up, took off the charger. The car started up, cranked about 5 cranks before started.
Dash voltage gauge now reads 14.3 V. Confirmed with my meter at the battery, 14.4 V
Tried it again, started up.. took about 5 cranks, which is a condition I have had in the past (aggravating)
I checked pins 6 and 14 again. With the ignition off (which is the only way I tested last time), pin 6 is 1.36V as well as pin 14. However, with the ignition in the Run mode (green circle on start button), pin 6 reads 2.45V and pin 14 reads 2.25 V.
Is that better?
The only thing I have recently changed on the car is added a front facing camera, which is hooked directly to the battery. I now realize that I should have tapped into a switched fuse or something under the hood, such as power windows, etc. I wonder if this camera is causing parasitic draw? I would think so, as tiny as it is. I just drove the car Saturday no issues for a few hours. Then come Monday night, no crank, no start.
Mike
Mike
Thank you
Long story short, issue was the starter motor, here's a video I took of the problem:
Part number is (GM 3231625), I got mine at Rock Auto (remanufactured).
Anyhow, I am back to no crank at all, dash and multimeter read 12.5 V, push the starter button, nothing happens, except the dash lights go black and turn off, then back on, no interior clicks. Left the battery on the charger for 1.5 days, still 12.5 V and nothing.
What I found is that when the car is running, it shows 14.4 V, and if when I get in the car and push the button once, if the voltage shows more than 13 + V I have a feeling it will start. How can this be, I thought these are 12 V batteries?? All connectors tight, battery, ground, alternator.
@C5 Diag , I have not looked at the CAN connectors yet, I will try this on Saturday. I have no idea what left to do at this point. I am in Chattanooga, TN. I am guessing you are in Florida. Hell, if I got it started, I would be willing to drive it to you, and pay you to get this working!
ANY other ideas on what to check? I only have a regular multimeter, and can't really afford a $500 scan tool at this time unfortunately. Time are very tough financially at home
I
I
I
