Can I install ??????
Old Feb 21, 2023 | 06:24 PM
BigJohnC6's Avatar
BigJohnC6
Default Can I install ??????
I have a 2013 Grand Sport. Can I install Corsa Extreme Mufflers Black tips 4.5, X-Pipe & Intake without doing a Tune. Also what Intake would you recommend & my car is completely stock don't really need Cam or Headers
Old Feb 22, 2023 | 10:40 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
No tune required for a catback/axleback. Save your money on an intake unless your doing it for looks. Not much to be gained there.
Old Feb 22, 2023 | 01:27 PM
sixen's Avatar
sixen
Cruising
Agreed. Always best to work from front to back when working on increasing flow. No point in the catback if you’re still limited up front.
Definitely no tune required tho for just catback
as for intake, I have the halltech. I know this is one of the ones most commonly used.
Old Feb 22, 2023 | 01:32 PM
StayinStock
Not quite what I was saying, most of the CAI's for these cars are little to no gain. I'd say the catback is a far better starting point and if he doesn't plan on going much further with cam/headers/ect. Then theres really no need to go away from the stock airbox unless he's doing it for appearance reasons.
Old Feb 22, 2023 | 01:38 PM
sixen's Avatar
sixen
Cruising
yeah I slightly misunderstood. I meant in sequence it’s better to work front to back. However I see he has no plans for cam/headers so it’s likely just for appearance/sound.. which then it doesn’t matter what sequence you do it in.
Although not sure why anyone would throw an intake without H/C. Seems pretty useless as it’s not really like a cool looking upgrade lol.
Old Feb 22, 2023 | 03:50 PM
Spaceme1117's Avatar
Spaceme1117
You already have the best intake for the car. An improvement to it would be to install a shroud to isolate it from sucking in hot engine bay air.
Old Feb 22, 2023 | 07:47 PM
gdmoore01's Avatar
gdmoore01
The GS already pulls in cool air through the functional front scoop in the bumper. It is also isolated from the hot engine air with a gasket and shroud. No improvement really necessary over stock.
GD
Old Jan 14, 2025 | 12:42 PM
03 Owner's Avatar
03 Owner
Deleted
To Can I install ??????
