Radiator hoses
Old Feb 21, 2023 | 09:53 PM
73ls1's Avatar
73ls1
Default Radiator hoses
My 06 has the original radiator and heater hoses. I'm going to change them because they have over 180,000 miles on my 06. Should I use oem hoses or go with silicone hoses Thanks Charlie.
Old Feb 21, 2023 | 11:10 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
New OEM is more than enough.
I installed new OEM when I bought a 2009 Z06 for HPDE driving at Sebring Speedway.
I wanted newer hoses when used at higher temps vs the original hoses that were 10 years old.
Same logic for the serpentine belt.
Do not forget fluid changes including the power steering fluid which is often neglected.
Old Feb 21, 2023 | 11:16 PM
torquetube's Avatar
torquetube
OEM hoses. As you've discovered, EPDM lasts a _long_ time. The only thing that goes wrong is the plastic T-joint, but that can be substituted with a metal tee.
I also like the OEM spring hose clamps because they don't rely on the elasticity of the hose itself to maintain constant tension. It does help to have several different spring clamp pliers handy, including one of the cable-operated ones.
Old Feb 21, 2023 | 11:30 PM
73ls1's Avatar
73ls1
All the hoses still look good .They are not brittle or soft. I have a brass t. I might run them a little longer.
Old Feb 23, 2023 | 04:08 PM
666lisa's Avatar
666lisa
The only reason to go siicone is for the differnet colors. Mine r still stock 1999
Old Feb 23, 2023 | 04:14 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
If the original OEM hoses lasted 180,000 miles, then stick with the OEM.
Old Jun 25, 2023 | 07:42 PM
pragmatic's Avatar
pragmatic
Came here looking for hose recommendations. The reason I'm looking is my 07 with 173,000 just split an upper radiator hose about 60 miles from home. So I wouldn't put it off. My hoses looked and felt good. I;m going with OEM.
To Radiator hoses
