No fob found
Old Mar 1, 2023 | 09:17 PM
NavyChief94!'s Avatar
NavyChief94!
Cruising
Default No fob found
I have a 2011 Grand Sport and battery went dead and after I replaced it neither one of my Fobs are recognized, I called a local place here in Jax FL about reprogramming them and was told that it is most likely a blown fuse for Ignition, BCM, Pass, IMMO, any help would be appreciated. And they told me reprogramming could be worse It could do more harm than good.
Old Mar 2, 2023 | 12:20 AM
gdmoore01's Avatar
gdmoore01
No reprogramming needed and they gave you some good advice.
Check the batteries in your fobs and ensure that they read 3+ volts or higher. New batteries read 3.3v.
Disconnect the battery cables from the battery & check the new battery with a volt meter to ensure that it is fully charged & should read 12.6v or higher. If not, charge it. Check the condition of the battery cable connectors and ensure that you have a good solid connection when you reinstall the battery. This will cause the cars modules to "reboot & reset" and hopefully that will resolve the problem.
If you have the same symptom, place the fob into the transmitter slot found in the glove box button-end first and buttons facing the passenger side of the car. This should register and start the car regardless of the condition of the fob battery.
If this fails, repost all the steps that you have performed and any DIC messages or other circumstances that may help us to help you.
GD
Old Mar 2, 2023 | 04:54 PM
NavyChief94!
Cruising
Thanks haven't tried fob in glove box yet.
To No fob found
