Disconnecting Battery
Old Mar 27, 2023 | 09:20 PM
Garibaldi's Avatar
Garibaldi
Default Disconnecting Battery
This is something that's never come up on my 2011 GrandSport in the 12 years I have owned it. I will be out of the country for two months. I can't use a trickle charger because there are no outlets in the space I park. Here's my question: Are there any negative consequences to disconnecting the battery until I return? I don't want to deal with a flat battery when I get back.
Tx
Garibaldi
Old Mar 27, 2023 | 09:25 PM
SixAddict's Avatar
SixAddict
Best bet would be to remove battery, place it where there are electric outlets and put a battery maintainer on it.
Old Mar 27, 2023 | 09:34 PM
ClothSeats's Avatar
ClothSeats
If you disconnect the battery, and then re-connect it after two months, the car will start with full gusto.
Old Mar 27, 2023 | 10:36 PM
sirdano's Avatar
sirdano
Should be fine. You buy them from the store the same way
Old Mar 28, 2023 | 06:36 AM
3X2's Avatar
3X2
How about a solar powered battery charger?
Old Mar 28, 2023 | 06:58 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The idle may be erratic for a little bit so an “idle relearn” (procedure below) may be required or if you have a “better” scan tool there is a function in there that will accomplish this quickly.
1. Start and run the engine in PARK for 3 minutes.
2. Turn the engine OFF for a minimum of 60 seconds.
3. Start the engine and run for another 3 minutes.
4. Engine should idle normally after 3 minutes.
After having performed the relearn procedure and the engine still does not run within normal idle speed, it will be necessary to drive the vehicle above 45 mph (70 Km/h) including several decelerations. Also
ensure that after driving the vehicle, let the engine idle for a minimum of 5 minutes.
If the engine has returned to normal idle speed, the relearn procedure is completed.
If the idle speed is still erratic or incorrect, restart idle relearn procedure.
Old Mar 28, 2023 | 09:07 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
i disconnect mine every winter while the car is elsewhere in storage, although it is on a maintainer. But that's 6 months. In your case, it'll be fine.
The only thing to remember, is that to get access again, you will need to remove the key from your FOB, to open the hatch manually. Then, once the battery terminals is on, you can unlock normally. Also, it may be a good idea to do a 'flood start' cycle (accelerator to the floor) when firing up...
Old Mar 28, 2023 | 02:08 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by tommyc6z06
- - - you will need to remove the key from your FOB, to open the hatch manually.
Try it ahead of time to make sure the key works.
Old Mar 28, 2023 | 02:37 PM
jaki30's Avatar
jaki30
Leave a window open a little in case you need to use the floor lever release.
Old Mar 28, 2023 | 02:54 PM
ClothSeats's Avatar
ClothSeats
This seems like a good excuse to buy one of those small, portable jump starters. They would be handy to have at times like this when you aren't sure what the state of charge of your battery will be.
Old Mar 29, 2023 | 08:36 AM
Brooklynguy's Avatar
Brooklynguy
I would disconnect mine for many months when I had it in FL. Just disconnect the neg cable and good to go. I would wrap cloth around the end so it cant touch any metal. It takes 60 seconds to remove and 60 secs to reattach. Done.
On my 2013 427 convert, I just needed to do a procedure for the power windows once it's rreconnected.check your owners manual for anything needed to be done after replacing a batt.
Old Mar 31, 2023 | 11:11 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
When I need to disconnect the battery I stuff a paper towel in the rear latch and/or the drivers side door latch. Thus no issue getting into the car.
Old Mar 31, 2023 | 11:57 PM
Chukman's Avatar
Chukman
I'm sure you could leave the car with any of us and we'll keep it charged & running until you get back :-)
Old Apr 1, 2023 | 08:45 AM
Moh765's Avatar
Moh765
Banned Scam/Spammer
he should be lol
To Disconnecting Battery
