Fuel cut out
Old Apr 3, 2023 | 01:25 PM
Daniel_M's Avatar
Daniel_M
Default Fuel cut out
Afternoon,
I seem to have a sporadic issue that i cannot pin point what is causing it.
Currently i know i have a bad sending unit, anytime I'm below 1/2 tank there's a really good chance the fuel gauge will shut off and the dash will start warning me about low fuel and to check the display, etc.
Now that isn't my sporadic issue, what is also happening is when my car is below 1/2 tank there's an even smaller chance (happened only 2 times in 2 years) where the car will start sputtering and cutting out until it eventually shuts off and will not re-start.
Now this is fixed by putting in a bit of fuel and it'll fire right up but the car never ran dry to begin with, i can still confirm there was 1/2 tank of fuel when i go to fill it all the way up and it only takes 5gallons or so to be full.
So I'm stumped as to why mimics running out of fuel when it has 6 gallons or so in it, also stumped as to why its so rare that it happens.
It's not fun driving and you see you've hit a half tank and now are unsure if your car will randomly shut off...
Any suggestions will be appreciated in diagnosing this.
Thank you,
2008 Base Auto, Stock aside mufflers.
Old Apr 4, 2023 | 08:50 AM
KENS80V's Avatar
KENS80V
Unfortunately the only way to get the true reliability back is to drop the tanks and replace everything inside both tanks. Your car is 15 yrs old now. Racetronix is a supporting vendor on this site and can supply most of it cheaper than the Chevrolet dealership. If you are planning to keep the car for many years than I would highly recommend this approach.
You could also purchase the internal parts from low mileage wrecked cars. There is a good thread on this site on what is involved in changing everything out yourself.
https://www.corvetteforum.com/forums...mp+replacement
Old Apr 5, 2023 | 12:08 AM
torquetube's Avatar
torquetube
Originally Posted by Daniel_M
Afternoon,
I think your fuel gauge problem and your car quitting are directly related. I don't think it's your level sender.
There's something wrong with your car's inter-tank plumbing - probably an internal leak - which is preventing net fuel transfer to the left tank. Eventually the tank runs dry and the car quits. The right tank is still full, which is why it doesn't take much gas to fill up the car.
The SERVICE FUEL SYSTEM messages are likely caused by the car detecting this problem.
Next step is to pull the DTCs to confirm.
Old Apr 5, 2023 | 07:27 AM
Daniel_M's Avatar
Daniel_M
I've kind of had the feeling i needed to do this since the beginning and i think it's time i pulled the trigger on that project. Although i could be wrong but is there a revised sending unit from GM that wont fail like the stock ones did?
It always has to do with the sending unit and high voltage/input i believe (i normally clear them as soon as they happen since my fuel gauge will just come back and start working again if i do). if it happens again ill make note to write down the exact code.
Thank you both for taking the time to help me out on this.
Old Apr 5, 2023 | 12:36 PM
torquetube's Avatar
torquetube
DTCs like P2066 and P2636 are set in response to signals from the sending units, but they typically indicate problems with the transfer system and not the senders themselves.
P2067 and P2068 are signal out-of-range codes that indicate problems with the senders or the sender wiring.
Old Apr 5, 2023 | 12:51 PM
Daniel_M's Avatar
Daniel_M
I believe i get the P0463 code. Although ill confirm the next time it happens, i can just run it to 1/2 tank or less and there's a good chance ill get it to come back.
Old Apr 5, 2023 | 01:42 PM
torquetube's Avatar
torquetube
P0463 suggests either a dirty sender or a poor connection.
Almost everything that goes wrong will require dropping the tanks, unfortunately. But you can get a better idea of the root cause not only by getting the DTC(s) but by watching the two fuel level signals on your scan tool. If the internal plumbing is working, the right fuel level should go down first, and only then should the left level start to drop. If your left tank is empty or low and your right tank is full, you have a transfer system failure.
Old Apr 5, 2023 | 02:43 PM
Daniel_M's Avatar
Daniel_M
Oh that's a good idea. I didn't think of doing that. Next sunny day we get ill have to do that to see what it shows.
Although I've come to terms that ill need to drop the tanks, going to collect the parts i need prior and set out to do it on a nice weekend.
Old May 2, 2024 | 11:58 PM
OMF's Avatar
OMF
I did have a flexible hose go bad on the inside and was sending little chunks of rubber up to the carb....the filter caught all those bits. Just wondering when you last changed the filter?
To Fuel cut out
