P0016
Old Apr 19, 2023 | 08:57 AM
C16dezzus's Avatar
C16dezzus
Cruising
Default P0016
Getting a p0016 code after doing a rebuild on ls3 c6. Car turns on & stays on only while on throttle if I let off it dies. Changed crank sensor on it and still does the same. Has anyone had this before?
Old Apr 19, 2023 | 09:44 AM
El_Steveo's Avatar
El_Steveo
Did you pinch a wire?
Old Apr 19, 2023 | 10:39 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A P0016 is a cam-crank “correlation” DTC and not a sensor one…since you said this is an engine rebuild you may have to get back into the engine…always helpful to fill out your profile concerning your car…this DTC info is for a 2007...a scope would be needed to interpret these cam and crank "falling edges"...a cam-crank waveform from my 01 below...cam sensor is the red trace…the “falling” edge is the right side of that cam signal.
Old Apr 19, 2023 | 10:50 AM
ClothSeats's Avatar
ClothSeats
If the crankshaft reluctor wheel was messed with during the rebuild, I hope it was re-installed in the correct position with the use of the positioning tool. If the engine ran fine before and the reluctor wheel was not messed with during this rebuild, this should not be an issue.
Old Apr 19, 2023 | 12:29 PM
C16dezzus's Avatar
C16dezzus
Cruising
the reluctor wheel wasn’t messed with at all. Engine was rebuilt b/c a piece of the pistol chipped and started knocking.
Old Apr 19, 2023 | 12:30 PM
C16dezzus's Avatar
C16dezzus
Cruising
thank you I will look into finding someone close who can do this.
Old Apr 19, 2023 | 12:31 PM
C16dezzus's Avatar
C16dezzus
Cruising
not that I’ve seen but I’ll double check everything again just to make sure
Old Apr 19, 2023 | 12:46 PM
myfunz's Avatar
myfunz
Old Apr 19, 2023 | 01:05 PM
C5 Diag's Avatar
C5 Diag
You may have difficulty finding a shop that has a scope or if they have one knows how to use it…dealerships don’t use one either !!
Old May 3, 2023 | 08:46 AM
C16dezzus's Avatar
C16dezzus
Cruising
so it did end up being outta timing, fixed it and got rid of the code!
Old May 3, 2023 | 09:05 AM
El_Steveo's Avatar
El_Steveo
Thanks for the closure! most people get a solution then never come back to tell us what the problem was!
To P0016
