Tech 2 folding top control module Iowa
Old Apr 20, 2023 | 02:46 AM
essixx's Avatar
essixx
Default Tech 2 folding top control module Iowa
I have a folding top control module I would like programed. I have the tech 2 and tis2000 can you help me? I'm will to pay for your time. Thanks for your time
Old Apr 20, 2023 | 11:07 PM
Dano523's Avatar
Dano523
Walk in the park.
Start with tis2000, go in as "ECM replace and program?, connect to car so it can pull the vin number, and keep moving forward in the program until you get to the modules list. Now go to the top control module in the list, then use the most current firmware file in the list, and firmware flash the module to the car.
Also, either make sure that the battery is fully charged, or hook up a 10 amp charger to the battery, so the battery voltage does not drop during the flash.
The only hard part of the math, is if you do have a hand held tech II, will need to connect that to a computer so you can run the unit in pass through mode. If your laptop does not have a RS232 port, then will need to pick up an approved USB cable to connect the tech II to the laptop on a USB port.
Amazon Amazon
Also, since chances are you will be running Tis2000 in a VM shell, will need to load the needed cable driver into the shell for it (what every os the shell is built on).
https://www.prolific.com.tw/US/ShowP...id=225&pcid=41
Old Apr 21, 2023 | 03:11 AM
essixx's Avatar
essixx
Wow! You make it sound easy. Thank you. You don't happen to live near Des Moines Iowa, do you?
Old Apr 21, 2023 | 10:02 PM
Dano523's Avatar
Dano523
No, but if you have all the needed gear, then PM me with a name and number, and can talk you through it over the phone.
Old Apr 27, 2023 | 05:28 AM
essixx's Avatar
essixx
Hey Dano523, Thank you for your great directions! When the weather warms up here I will give them a try
To Tech 2 folding top control module Iowa
