P0621 Trouble
Old Apr 24, 2023 | 03:23 PM
Rubysc6's Avatar
Rubysc6
1st Gear
Default P0621 Trouble
Just recently had this problem w my 06 Vette. I had code P0621 show up and i’ve seen other posts of people fixing the same issue by changing to oem spark plugs or checking the horn/alt fuse. The only problem is i just recently replaced my spark plugs to oem plugs last week and my horn works so i don’t believe it’s a fuse. Any ideas? when i took it for a drive my battery voltage dropped down to about 9v!!! Left the battery charging all morning too and still doesn’t hold charge.
Old Apr 24, 2023 | 07:44 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I do remember a TSB concerning this issue with non OEM plugs but if you look at the code setting criteria for this DTC they want you to check for an open or short to voltage on the “turn on” alternator connector wire which is the red wire on your alternator connector….if you back probe that wire key on engine off you should see .5 to 1.3 volts and with the engine running 8-11 volts…if you see system voltage key on engine off that’s not good or 0 volts with the engine running…that is why you may have seen 9 volts because the alternator did not receive that 8-11 volt turn on signal (which is pulse width modulated) and was not charging.
