2009 corvette LS3 430hp stock
Old Apr 25, 2023 | 12:20 PM
texas speedracer's Avatar
texas speedracer
4th Gear
Default 2009 corvette LS3 430hp stock
hi, I'm looking at installing AC Delco sparkplugs. what should i install for plugs 41-110 0.40 gap or 41-962 0.60 or 41-985 0.40 gap I'm Cunfused!!
I installed 41-962 0.60 GAP plugs are these the correct plugs?? OR do i install the 0.40 GAP plugs??
Old Apr 25, 2023 | 01:52 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Hi Gary: I would suggest asking this in C6 Tech or reach out to a moderator and ask them to move this.
You will get much better results there.
Old Apr 25, 2023 | 02:38 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome.. moved you here
Old Apr 25, 2023 | 02:39 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome!
Old Apr 25, 2023 | 05:01 PM
texas speedracer
4th Gear
thankyou very much
Old Apr 25, 2023 | 08:29 PM
kkupec02's Avatar
kkupec02
welcome
Old Apr 26, 2023 | 11:38 PM
HOXXOH's Avatar
HOXXOH
I used 41-110 plugs from day 1 (OEM) through 161K miles. If you run too lean at WOT, you might lose an iridium tip or two, but it won't happen on a stock tune.
To 2009 corvette LS3 430hp stock
