LS7 Build Piston Material Choice
I am building an LS7.
Crank HP range 560 to 600 @ 6500 RPM.
The engine parts vendor that I am working with has recommended a 2618 piston material.
Piston Vendor : RaceTech.
This is a high performance street build.
Given the past, I have only used 4032 pistons.
From a reliability viewpoint, is it a mistake to use 2618 pistons?
I am not looking to change pistons every 50 K miles.
I am also not looking for crazy amounts of piston slap when cold.
Any advice is appreciated.
Best Regards,
Bruce
on your NA motor, I'd go with 4032 alloy
