Got a new AC compressor installed, no good?
Old May 11, 2023 | 10:45 PM
Corvettechris86's Avatar
Corvettechris86
Default Got a new AC compressor installed, no good?
I ordered a reman gm ac compressor kit with everything including the expansion valve and condenser etc. It blows cold air when moving but at idle it is only “cool”. The shop said the compressor tested bad at idle, something about 50psi but works fine when the rpms increase ever so slightly. Will this compressor last like this or get worse? The shop owner doesn’t seem to think it will go bad just won’t blow cold at idle. Anyone? Labor came to $1300 and not trying to do it over again.
Old May 12, 2023 | 03:22 AM
JoeE45's Avatar
JoeE45
I’ve never heard of a bad AC compressor causing AC to not work at idle only. If it was defective i’d imagine it wouldn’t work at all. Make sure fan kicks on with AC, sounds more like an airflow issue. Have another shop take a look at pressure levels as well
Old May 12, 2023 | 04:34 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Something doesn't sound right.
Old May 12, 2023 | 06:46 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d check and see if your AC fan is operating…your condenser needs airflow over it at idle to keep things working properly…it’s good to know what the high and low side pressures are too.
Old May 12, 2023 | 08:02 AM
Corvettechris86
I could hear the high speed fan kicked on, also weird the car seems to run hotter when moving. Usually runs 192 consistently while moving, now it’s 217-222 moving. They rechecked the pressure on the high and low side, told me the compressor isnt building pressure at idle most likely because the pistons in the compressor aren’t sealing properly.
Old May 12, 2023 | 08:58 AM
ClothSeats's Avatar
ClothSeats
If a new drive belt wasn't installed along with the new compressor, I would install one now.
Old May 12, 2023 | 09:19 AM
Corvettechris86
I supplied a new ac delco belt plus we just did a Powerbond balancer pinned to the crank incase i decide to get a Vortech V3 in the future.
Old May 12, 2023 | 10:22 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
A/C operation is science...
Take it to an automotive A/C specialist.
All the failure modes are straightforward to diagnose.
No need at all for an 'I think it must be the....' diagnosis.
Old May 12, 2023 | 10:53 AM
Corvettechris86
Something really weird too, the ac control module was like freaking out for a little changing passenger temps.
Old May 12, 2023 | 10:35 PM
vetteJPJ's Avatar
vetteJPJ
Check the car's cooling system. Obvious stuff like Coolant level, leaks etc. May be some air in system. My son's Camaro SS 6.2 (2016) Had weird A/C issues as well as the fans staying on even when car was shut off. It was a coolant level sensor.
To Got a new AC compressor installed, no good?
