Pushrod Length Checker?
https://mantonpushrods.com/products/tools/
So first thing to do, is pull a few of the lifter sapart to pull all the oil out of it, so you can reassembly and measure that amount of total travel that pistons has in the lifters to start with when you only have to fight are pressure alone, to give you the amount that the lifters should be preloaded in the end.
Note, for me, I use the mill with Dro. Hence backward drill bit n collet or chuck, touch off to the seating button and Dro out the DRO, then compress all the way down to full compress the lower spring via the piston, the half of that distance is the amount that the lifter needs for preload.
Also, if you are pulling the lifters apart, would be a great time to add in limiting rings.
Note with limiting rings, need to measure that amount of total travel of the piston since it going to be reduced, and then use that half amount for pre load instead.
Last one, is to make sure that the button ends of the push rod checker, is the same sizes as the push rods you are going to use as well.
Close enough for 'Government Work' ....
And they are quiet.
$20.99 + $11.99 shipping plus tax
Adjustable from 6.8 to 7.8 inches.
Hopefully you can get yours sounding better without pulling the heads and changing lifters. If the sound is kind of uniform across the motor and not isolated like mine then I bet putting some more preload on the lifters will help. I would def measure to where you’re at but I bet you prob need a 7.425 pr. Until you get an adjustable pushrod you could always do the rocker bolt turn method to get an idea. If done right it’s pretty accurate. I know I got an issue with mine, that I honestly believe is head related, but I think this BTR cam is just a noisy cam on top of it. I kind of wish that I had went with a Cam Motion cam now. I know Comp used to grind BTR’s cams but they don’t now and they wouldn’t tell me who does when I asked them.
I found a guy selling his factory heads He took off his grand sport around 32,000 miles that I thought about buying because I’m pretty sure my issue is related to the heads. He’s asking 1000 for them both do you think that’s a fair price or too much?
I’ve heard good things about the GPI cams. I’m happy with the performance of the BTR cam but it’s driving me crazy that I can’t figure out where all that noise is coming from. What makes it so aggravating is the fact that I had motor pulled and had all new bearings done as well as the heads cleaned and a valve job so you’d think it would be perfect. Sounds like crap tho as you heard in the video lol
