Serpetine belt
Old May 20, 2023 | 04:20 PM
Sayfoo's Avatar
Sayfoo
Default Serpetine belt
Stock base '08 here with 117k miles.
I'm assuming it's a good practice to replact the belts, but I question if anybody has actually had a belt failure on a stock LS3 motor that is running fine, with the belts looking ok.
Thoughts???
Old May 20, 2023 | 04:22 PM
ClothSeats's Avatar
ClothSeats
If you keep an eye on it from time to time, the belt will give you plenty of warning ahead of failure by showing cracks or other wear.
Old May 20, 2023 | 04:32 PM
Dano523's Avatar
Dano523
Check the inner rib sections, and if you see cracks, replace the belt.
Trust me, at 117K, if the original belt, that would be pulled and stored in the back cuby hole for back up, and motor would be wearing a new belt a long time ago. Also, don't forget to replace the inner/lower A/C belt as well.
To Serpetine belt
