Odors
Old May 24, 2023 | 07:08 AM
Dreamer2's Avatar
Dreamer2
Default Odors
2008 Z51 manual C6 here. After some time on the road, I feel like I smell gear oil. Definitely could simply be exhaust, brakes or anything else. It’s not overpowering but I figured I’d ask.
Old May 24, 2023 | 10:46 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
You need to do some checking in the engine bay & underneath. If the odor occurs after the engine heats up fully, there may be a leak somewhere that's smoking on the hot engine or trans. Best is to raise on jackstands or "borrow" a lift so you can fully search from the underside.
Old Jun 1, 2023 | 03:52 PM
thebarzeen's Avatar
thebarzeen
I get the same.... mine is a valve cover that's leaking a few drops of oil onto hot headers. I haven't noticed a drop in oil level after monitoring it for a few thousand miles so I'm not worried about it. Also made worse because the cabin air filter door is messed up on my car.
Old Jun 1, 2023 | 04:18 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I doubt that you are smelling gear oil. That stuff stinks to high heaven. You will not mistake it for exhaust or brake smell.
Tom
Old Jun 3, 2023 | 08:22 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
Yep, gear oil has a very distinctive smell. You can not mistake it.
Old Jun 6, 2023 | 08:34 AM
Dreamer2's Avatar
Dreamer2
Default Exhaust Leak
I conducted the shop vac, soapy water exhaust leak test. I found a leak at one tail pipe connection(secured with oem clamp) including some soot. It looks like a small hole around the seal between the two pipes. Also, the exhaust tip/pipe connection and exterior NPP nut/pivot leaks some exhaust.. Doesn’t leak at idle. Pressure probably not high enough.
To Odors
