Torque tube removal??
Old Jun 1, 2023 | 07:03 PM
jonjoy's Avatar
jonjoy
Default Torque tube removal??
I am about to embark on this repair, Anyone got the link to the step by step that's on here some where? anyone in AL or GA want to work with me on mine and then we do yours or any other thing, like a cam, I've done two and heads
Old Jun 1, 2023 | 08:44 PM
furious427's Avatar
furious427
If you have a base car you won't have to deal with tranny/diff coolant lines, but this is basically everything you need to know.
https://www.corvetteforum.com/forums...full-pics.html
Old Jun 2, 2023 | 03:11 PM
C6VetteLover's Avatar
C6VetteLover
See if this video helps
Old Jun 2, 2023 | 05:46 PM
russ472's Avatar
russ472
a z51 base has the cooler lines
Old Jun 2, 2023 | 06:09 PM
furious427's Avatar
furious427
Ok I always thought a Z51 was not base, my mistake, either way that thread will help.
Old Jun 3, 2023 | 08:58 AM
ddartford's Avatar
ddartford
Default Been there.
I changed my torque tube last year. I was not bad. I changed the drive axles and all my shocks at the same time. Dropping the entire back suspension sounded bad, but wasn't too bad. I did mine in my garage with the car on blocks about 2 ft off the concrete. Backed it all out sitting on a floor jack. Get help lowering and moving. The jack carries the weight on the xmsn pan but someone needs to guide the engine side so as to not tear **** up. BTW, when I bought my new shaft they sent 2. I have a new torque tube 8905-9715 for sale. For the same reason I have extra drive axles, both for the base and the Z51 (which I have).
Old Jul 31, 2024 | 07:45 PM
twitty2fast's Avatar
twitty2fast
i got an underhoist support rated for like 1500lb will that be enough to hold the back end??
Old Jul 31, 2024 | 09:14 PM
furious427's Avatar
furious427
Definitely.
Old Aug 2, 2024 | 10:14 AM
Kenny94945's Avatar
Kenny94945
Best of luck OP, Jon.
Many have done this DIY and my FWIW comment is I hope you have a lift and all the tools.
I would "hate" to do this job on jack stands
To Torque tube removal??
