2006 C6 transmission
Old Jun 13, 2023 | 07:51 AM
Csmvallade's Avatar
Csmvallade
1st Gear
Default 2006 C6 transmission
Team I lost 5/6 gears in my T56 6 speed transmission. The code stamped on the side is TUET 4430 and 61UCD T003002. I am finding a lot of T56 out there to put in my car but have different codes. Can I interchange as long as they are a T56 and 27 spine.
Old Jun 13, 2023 | 09:22 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, and congratulations on your C6!
This is more of a general “Hello” section. I would encourage you to post your question in the C6 Tech section at: https://www.corvetteforum.com/forums...-2005-2013-14/
Best wishes for an easy (and inexpensive), fix.
Old Jun 13, 2023 | 09:30 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Moved you here... good luck.. and welcome to the forums
Old Jun 13, 2023 | 10:55 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
TUET4430 is a Z51 (MZ6 ratio) T56 with fluid pump. The short answer is yes you can use non-Z51 T56 with 27 spline if you plug the fluid lines.
You most likely stripped the splines that keeps the 5-6 driven gear on the main shaft.
__________________
Old Jun 13, 2023 | 11:04 AM
ClothSeats's Avatar
ClothSeats
Are you sure it is not a shift linkage problem? It could be related to the internal transmission shifting components rather than a gearing failure, especially if you aren't hearing any bad noises coming from your transmission.
Old Jun 13, 2023 | 08:12 PM
kkupec02's Avatar
kkupec02
welcome
To 2006 C6 transmission
