Hey, I think I've read every spacer related post on this site as it relates to C6's, but I just want to confirm from someone who has done it. Will putting 5mm spacers on the front and rear of a 2010 Grand Sport require longer studs or anything else besides just bolting on the new spacers? I am close to pulling the trigger on the below product. Thanks!
On my 2011 GS, my right rear wheel sticks out slightly farther than the left rear wheel.
2 years ago, I fixed this by installing a 5mm spacer on the left rear in order to get them more even.
I did not used longer wheel studs and have never had a problem ... However, I would not use thicker spacers than 5mm without using longer studs.
Your Amazon link looks like the same 5mm spacers that I purchased.
Interesting, so does my 2011 GS. I thought it was an alignment issue, maybe the left had more negative camber so it looked a little more tucked in, but nope... Right side still sticks out slightly further after getting it aligned. Ever find a reason why?
The locator pins in the rear cradle that fit into the holes in the rear subframe may not align perfectly so as both wheels may not be the exact position to the rear fenders after the whole thing gets tightened down (this is certainly no 'hand-built' car). And the locator pins that fit into the holes are non-adjustable, so all you do is fit the cradle pins into the subframe holes and tighten up the rear cradle mount bolts ... Ya get what ya get.
As they say ... It's close enough for government work . . . .
Here you can see those 2 big locator pins in the photo of the rear cradle assembly:
