Zip Corvette Rivet Nuts
Old Jul 7, 2023 | 03:28 PM
notoriouslyKEN's Avatar
notoriouslyKEN
8th Gear
Default Zip Corvette Rivet Nuts
Anyone know how to install the Rivet Nuts for the radiator support cradle? I bought these from Zip Corvette but I don't understand how to install them. They note "To install these rivet/nuts correctly, use a bolt & washer to pull the nut into place when installing, then remove the washer and reinstall the bolt holding the assembly to the frame."
I watched youtube videos on installing without using a rivet tool and have tried different combination of washers/nuts to try and get it to expand in the frame but have had no luck. Anyone done this before and can provide guidance?
Old Jul 7, 2023 | 10:49 PM
davidfarmer's Avatar
davidfarmer
Buy a rivnut tool and save yourself a lot of work .
Old Jul 8, 2023 | 08:12 AM
notoriouslyKEN
8th Gear
Yup. Bought the tool and took 5 minutes to install the 4 rivnuts. Spent about 2 hours prior trying to figure out our without the tool.
To Zip Corvette Rivet Nuts
