ABS/EBCM Module
Old Jul 19, 2023 | 02:31 PM
Kalebspec's Avatar
Kalebspec
Default ABS/EBCM Module
My ABS/EBCM module is out in my 2009 C6 Z06. This part is discontinued. What are my options? Any help or insight would be greatly appreciated! Thank you all!
Old Jul 19, 2023 | 08:00 PM
torquetube's Avatar
torquetube
What are your symptoms? Some apparent EBCM problems are actually wiring problems.
You can source a used unit. Keep in mind that the 09-13 cars have Bosch ABS with a totally different EBCM and BPMV than the 05-08 Delphi ABS cars.
Old Jul 19, 2023 | 08:23 PM
wjnjr's Avatar
wjnjr
These guys fix ABS modules:
https://www.absfixer.net/
Old Jul 19, 2023 | 08:58 PM
Kalebspec's Avatar
Kalebspec
ABS light is on, parking brake indicator lightstays on, traction control doesn’t work, steering is really tight. Throwing two codes C0040/C0035. Took it to a shop and the computer will not talk with the EBCM and the voltage coming off of the EBCM is 11 volts.
Old Jul 19, 2023 | 08:59 PM
Kalebspec's Avatar
Kalebspec
spoke with Brandon and he says he doesn’t fix that year.
Old Jul 20, 2023 | 12:37 AM
torquetube's Avatar
torquetube
Did you retrieve the codes at home? Those codes are stored in the EBCM, so the computer is talking.
C0035 and C0040 are the LF and RF wheel speed sensors, respectively.
I'd start by inspecting and cleaning up the big electrical connector at the EBCM.
To ABS/EBCM Module
