Hey guys! New to the forum!
purchased my c6 base back in october
been delaing with this issue ever since
i bought it.
it used to say bank 1 and 2 were running lean
And now thise went away but its giving me these 3 codes (p0101, p0103,p0103) AFTER i put in a new mar sensor, its an AC Delco.
car used to drive with real power now it just lags and hesitates on start up.
any info would help thanks!
Welcome to the Forum !!…first thing you really need to do is fill out your profile in “about me” so we know what model year, trans, any mods, a tune etc. that way we don’t have to pull all this information out of you when you’re having trouble…did you have these 2 trouble codes prior to replacing the MAF sensor ??…where did you buy it ??…you can try disconnecting the MAF sensor and start the car up and see if runs a little better…do you have a DVOM and know how to use it ???…what does your MAF sensor read in grams/second at idle and if you have a MAF voltage data PID what does that read at idle ??
