Well seems like my 05 is in need of a new Harmonic Balancer.
I would like to get this taken care of as soon as possible; already placed an order for an ARP bolt.
I'm curious to know what other parts are needed when replacing the HB.
Can someone supply me with a shopping list?
Thanks in advance.
1. New bolt; GM or ARP.
2. New balancer; I recommend Dayco or ATI.
3. New front cover seal for balancer.
4. Balancer install tool; Summit sells a very nice one.
5. Balancer puller.
6. Flywheel locking tool.
Probably a good idea to get some engine coolant as well.
It's not a difficult job, just a lot of work mainly to get everything out of the way to get to the balancer.
Thanks!
I received the new bolt just yesterday; Went with an ARP branded one
Plan to order this front cover seal next:
Then on to purchasing a PowerBond PB1117SS.
Get a friction washer, P/N 12674588. It goes behind the pulley. If you have an early production '05, there's a chance you don't have one. If you do, it's probably the old style with a rubber lip around the edge. It will usually come out attached to the pulley. Just make sure there's only one of them in there before you install the new pulley.
I hear alot of talk about "pinning" the HB.
Anyone familiar with this? Any extra parts needed?
Pinning has been covered in many threads. It's probably best to refer to one of them.
It involves drilling a hole through your pulley into your crankshaft and inserting a pin to prevent rotation. No naturally-aspirated C6 was made with a pinned crank and the vast majority never spun a pulley. In my opinion, most of the spun pulleys you hear about are either 1) early '05s, or 2) replacement pulleys that were torqued incorrectly. The torque procedure is critical and can be difficult to do in the available space. I think it gets screwed up a lot.
Pinning is recommended if placing extra load on the pulley like with a supercharger, or if your pulley has spun before. Some owners do it as an insurance policy.
Many of us have seen pulleys spin that were installed correctly, although not common in a regular street car. If a shop is doing it, they should know how to pin in. There are multiple methods, either will work.
I have the ATI pin kit, I always use their method.
This is a common issue on the LS motors. It the cheap balancers, you can go back with a GM one but I would used a ATI balancer. You don't need to pin the crank though unless you are planning on supercharging your engine. If you are going to do that then you need to pin it. ATI sells a pin kit as well but when you buy your supercharger it should come as part of the kit.
If your already doing everything, why not just add a pin?
Because you do take a chance of messing up a crankshaft or if you are not careful getting metal in the oil pan. You should be fine if you are careful but why take the chance if you do not have to.
