c6 auto trans fluid leak
Old Aug 16, 2023 | 03:23 PM
aj15479's Avatar
aj15479
Default c6 auto trans fluid leak
Had my c6 up in the air checking fluid leak and found fluid dripping from bottom of pan. When we removed the front inspection plug there was no fluid coming out. We could not determine the source of the leak but guessed it could be the pan gasket.
Transmission performs/shifts normally and I am getting no errors but I don't have a code reader, I hope to pull codes later.
If there was an internal issue would there be fluid coming out of the inspection cover. I am hoping a transmission service will fix the problem. Any and all thoughts appreciated.
2005 c6 auto 74000 mi.
Old Aug 22, 2023 | 01:08 PM
rainmaker gs's Avatar
rainmaker gs
I had a wet pan on my A6 2011 GS and mechanic cinched the pan bolts down a bit, seems to be working.
