Electronic Suspension Control
Old Aug 22, 2023 | 12:40 PM
Tim81's Avatar
Tim81
Default Electronic Suspension Control
Can someone tell me where this module is located in a C6? Thanks
Old Aug 22, 2023 | 12:50 PM
Colonel's Avatar
Colonel
See if this video helps. It's for a ZR1 but I'm guessing other C6s with MRC are the same.
https://jimmero.com/mrc-suspension-u...ation-options/
Old Aug 22, 2023 | 01:15 PM
Tim81's Avatar
Tim81
Thanks for your quick response. Much appreciated.
Old Aug 22, 2023 | 01:16 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you have magnetic ride control it’s probably located in the same place as the C5 that I had…inside the left rear floor compartment lid.
Old Aug 22, 2023 | 01:29 PM
Tim81's Avatar
Tim81
​​​​​​​Thanks C5Diag, of course my 06 don't have a escm but I'm hoping that the connectors are there to measure some voltage.
Old Aug 22, 2023 | 03:32 PM
C5 Diag's Avatar
C5 Diag
If you don’t have it the connectors shouldn’t be there…why do you want to measure voltage there with EBCM DTC’s ???…just curious.
Old Aug 22, 2023 | 05:43 PM
Tim81's Avatar
Tim81
Yes the wiring diagram shows that ignition 1 circuit is the same one as the EBCM. Just thinking it might be an easier spot to get to rather than the connector at the EBCM when the engine is hot. If I have the correct voltage there it would indicate no power problems with the fuse box. Just a thought.
To Electronic Suspension Control
