Bad fob In a Jam
Fob #1 would not operate anything when properly inserted into the glovebox slot. New battery or old battery, made no difference. I am gonna make sure the wires are connected on the glovebox slot because that door and some of the dash has been apart to install a new radio many years ago.
The #1 and #2 fob are now working as normal now that we are home. The lights flash and they will lock and unlock the doors remotely and I can start the car. We all tried operating the #2 fob when they arrived with it while in the parking lot. and the lights didn't flash nor would the doors unlock via fob buttons. I was worried the car had another issue, but I unlocked the door via the door button and started the car with no issue. Strangest thing is the old #1 fob (with new battery) will now operate everything as normal here in the garage. Gonna look for an issue with the fob slot, as that should have worked and saved us a lot of trouble.
Note, it take about 15 mins of driving above 2K rpms before a good low battery to fully charge back up again. If driving is just stop and go with the ACC on, may take even longer. So on that note for a while set your DIC to voltage, and keep an eye on it. It should be 14.1~14.3, and if in the 13.5V range of lower, may be time to check the alternator for possible clean up.
https://www.corvetteforum.com/forums...nator-fix.html
So on that note of low voltage glitched RCDLT module, pop the hood, remove either the positive or negative battery cable from the battery (which ever is easy to pull off), touch the pulled cable off it battery terminal, to the other cable that is still on its battery terminal to fully discharge all the modules in the car, then reconnect the pulled battery cable back to its battery terminal. This will hard reset the modules in the car, and the fobs should start working again.
When you get back in the car, remember to re-index the windows,and stop by an auto parts store to have the battery load tested to see if it still good/need to be replace.
If battery is still good, then time to check the battery cables on both ends (where the ground cable bolts to the engine block, and where the postive cable bolts to the starter solenoid), and if your not driving the car for a few days, get it on a battery tender.
Note here, if car is lefts on battery tender long term without driving it, then depending on the tender, it too can voltage glitch the modules as well. So get in the habit of when you are pulling the car off the tender long term, press the unlock button on the fob to see if the lights do flash before you pull the tender off the car. If lights to not flash, the do the cable pull and cap discharge cable taps to discharge the modules as your pulling the car off the tender, and hard reset the modules on the battery cable reconnect.
As for battery cable nut, is a 10mm, so pick up a cheap 10mm socket, extension, and shorty ratchet to keep in the cubby of the car for this, as well as other tools that may come in handy for the car on the road.
Just remover to have nothing touching the disconnected battery terminal when you are touching it cable to the other connected post, or just remove both cables from the battery, and touch them together a few times away from the battery itself.
Short of that, could be that the RCDLR is working fine, but the problem is that the RCDLR signal is not making it way to the BCM on the class 2 lan bus through the Jx206 connector.
The Jx206 splice block connector is in the passeger foot well, and to the left of the Bose amp location on the second screw line down on the amp.
In the below photo, top left hand side, you will see a thing that looks like it sliglty glowing green. Its actualy silver, and it clipped to the plastic in the foot well. Unclip is, pull it up, and on the bottom of it, will see that the wires are just pushed into the splice block. So on that note, you can use the class 2 diagram to see when two wires you want to check or just push/pull each wire in the block to clean up its connecting to the slice block clips.
Short of a problem at the splice block and still on the data 1 bus, could be the BCM connectors that has a corrosion problem that you need to clean them, or could be back up in the dash above the radio, with either corrosion problem at the RCDLR connector, or cold solder joint problem of the board header pin soldering to the board itself.
You don't list your location, but if your in the Denver area, can swing by to make sure work of getting you back on the road again for free.
Now all I have to do is pull the left fuel tank and look for a gas leak. Garage now smells like gas. The vette is gonna get parked in my shop today.
https://www.corvetteforum.com/forums...ump-09-c6.html
GM used to change them for free, but the time ran out of that.
If you are going to change the drivers side fuel pump (will come with fuel level sensor), then may as well pull the other tank to change it fuel level sensor as well. Over time, the swiper arms on the fuel level sender wear out first on that passenger side, and cheap enough to drop a new one in on that side, while you are changing out the fuel pump on the driver side.
Note, make sure you get the correct year of fuel level sensor, since they reversed the way the sensor reads in later years.
Hence drivers side has an actual pressure pump, while the passenger side has a siphon jet pump that is driving off the drivers side pressure pump. On the vet, the passenger side tank fuel is used first, then once its empty, the last half of the fuel is pulled from the driver tank. Since the passenger side tank is the first to be drained, its fuel level sending unit is the first to go out (its swiper arms wear out first).
That's a fair question as it will only work one way
