Lifting engine
Old Sep 17, 2023 | 08:13 AM
Dreamer2's Avatar
Dreamer2
Default Lifting engine
Doing the oil pan. Dropping cradle. Can I jack engine at bellhousing? Trying to avoid removing leaf spring but cannot access HB with it in place.
Old Sep 17, 2023 | 11:37 AM
Ogre39's Avatar
Ogre39
https://www.corvetteforum.com/forums...an-gasket.html
Old Sep 17, 2023 | 03:47 PM
Dreamer2's Avatar
Dreamer2
I searched and read most past posts. I don't have an engine hoist and some mention raising at the HB without removing the leaf spring.I don't see how I can access the HB with the spring in place. I read that raising the engine at the bell housing may be an option but it is not mentioned that often. So consensus, bell housing?
Old Sep 17, 2023 | 09:58 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Yeah, you'll be fine but you're not jacking it up but rather just preventing it from falling.
Use a short section of 2x4 to spread out the load when you place the jack underneath.
Old Sep 20, 2023 | 09:55 PM
rsb213's Avatar
rsb213
be careful if you have a remote clutch bleeder installed and you do this. ask me how I know
To Lifting engine
