throttle response
Sep 30, 2023 | 03:37 PM
throttle response
does anyone make a throttle response controller for a 2005
Sep 30, 2023 | 05:55 PM
Quote:
Originally Posted by
stevebrochu
Google> Petal Commander.
Sep 30, 2023 | 09:56 PM
Not for the E40 ecm that is in the 2005 vet, and the only way to pull that one off, it to go into the ECM to throttle re-map in the tune instead.
EFI live will have then needed tables in stock from, while HP tuner you have to add in some PID's to get the needed tables isntead.
And no, not for the novice to remap, since have to re-work multiple tables at the same time, and if you get any of them wrong, will brick the ECM.
Oct 1, 2023 | 08:53 AM
Cherokee Nation
Nope, none for 2005. As Dano indicated, it's a one year only ecm.
Oct 2, 2023 | 04:04 PM
Remapping is the best solution i& you don’t like GM’s exponential curve .
