C6 problems
threads about those being the most common problems. How common are those problems and about how much is the cost to repair them at a dealer? I've tried to get dealers to tell me the approximate costs
to repair them and they say, you need to bring it in before we can give you a quote. Thanks
Cost of this repair at a stealership will be high. Probably $1500 or more because there is a lot of labor involved. If you are able-bodied, you can do this job yourself.
The fuel tank problem shouldn't be an issue. I think by this point most C6's that will have had the problem, have had it and this fix was covered for free by GM. But I think that coverage has expired by now so if you have to get this fixed at a stealership, it will likely be $1000+.
As for the shifter issue, I think you mean the broken linkage that auto cars can have, this is easy to fix yourself but at a stealership shouldn't be more than a couple hundred dollars.
C6 Corvettes overall are probably some of the most reliable cars ever made. Most never have any major issues. Buy it.
Since ALL C6''s are out of warranty, a dealer is probably the most expensive place to get things repaired. While some people think 36K miles is a lot on a 13 year old Corvette, even those people drive their other cars well past that mileage. Don't let fear of problems control your enjoyment of life. Learn to accept that when things go wrong, most can be fixed.
BTW, always use top tier premium fuel. I prefer Chevron with Techron to keep the fuel system clean.
Then, enjoy the hell out of owning one of the best cars GM ever produced.
Finally, never ever ever ever, take it to a dealership for anything!!!!!!
I have had 2 C6's and both have had the balancer wobble. It's not a terribly difficult job, but will run around $1500 if a dealership does the work. When I bought my 2010 GS I also purchased a service contract through Veritas. Cost was $2800. This Thursday my 2010 goes to the dealership to get a new balancer and it will cost me my $100 deductible. I am a firm believer of pay now or pay more later and a warranty (service contract). If I guessed correctly, between now and when my car posts 85,000 miles I should have had this warranty pay for itself and then some. If in doubt buy a warranty and figure the cost into your current budget. If you get a $500 deductible, the cost should be around $2000, or one major unexpected repair...
