C6 starter replacement
Old Oct 10, 2023 | 12:32 PM
C6Jace's Avatar
C6Jace
4th Gear
Default C6 starter replacement
Just recently replaced the starter on my 2008 c6 base after the car has been sitting for a few months. Now the car just clicks and doesn’t start. Bad battery or bad starter?
Old Oct 10, 2023 | 01:01 PM
LCZ06's Avatar
LCZ06
Always start with the battery. Was it on a trickle charger? You can take it to almost any auto parts store and they will check it out for free.
Old Oct 10, 2023 | 01:22 PM
C6Jace's Avatar
C6Jace
4th Gear
Didn’t have it trickle charging , I had the car hooked to jumper cables in the video.
Old Oct 10, 2023 | 02:23 PM
cthusker's Avatar
cthusker
Sitting for a few months the battery probably doesn’t have full charge... unless you charged after sitting that long or had it on a tender.
Old Oct 10, 2023 | 02:31 PM
C6Jace's Avatar
C6Jace
4th Gear
So even if it’s on jumper cables it could still be a bad battery? I’ll get the battery tested for sure , I was under the assumption that maybe the starter was faulty.
Old Oct 10, 2023 | 02:41 PM
C6Jace's Avatar
C6Jace
4th Gear
After watching the video again , are the dash light suppose to shutoff like that while starting? Looking low in juice.
To C6 starter replacement
