Spark Plugs
Old Oct 11, 2023 | 03:28 PM
KBu's Avatar
KBu
Default Spark Plugs
Just a quick note on something that happened that seemed odd."13 GS less than 13k miles develops a miss on cylinder #2.swapped coil packs and no change.Pulled valve cover,checked valve springs,lifters and did a compression check.Everything checks good.Friend suggested swapping plugs with another cylinder.Wa la,that was the problem.Missed moved to the swapped cylinder.New set of plugs and everything good as new.Lesson learned again,check the basic things first.
Old Oct 11, 2023 | 04:41 PM
jonjoy's Avatar
jonjoy
and you wouldn't have looked at the plugs first?
Old Oct 12, 2023 | 07:59 AM
KBu's Avatar
KBu
Yep,did "look" at the plug and it "looked" perfect
Old Oct 13, 2023 | 12:35 AM
JackDidley's Avatar
JackDidley
Wow, only 13k miles ??? I expect plugs to go 50k.
Old Oct 13, 2023 | 11:58 AM
KBu's Avatar
KBu
Me too
Old Oct 13, 2023 | 02:45 PM
old motorhead's Avatar
old motorhead
What plugs were in it?
Old Oct 14, 2023 | 09:01 AM
KBu's Avatar
KBu
The original AC-Delco
Old Oct 14, 2023 | 01:08 PM
miami993c297's Avatar
miami993c297
Will you provide a picture of the culprit plug?
Old Oct 14, 2023 | 07:10 PM
KBu's Avatar
KBu
Sorry,the plugs were thrown away so I don't have any photos.Plug color was a nice honey brown and no wetness.
Old Oct 16, 2023 | 11:59 AM
Warren Seale's Avatar
Warren Seale
I had 2 plugs go bad when I had my 06. They only had 15000 miles on them. Due to the low miles, I just replaced the one bad one then a few months later another went bad. At this point I went ahead and replaced all of them. They were the original ACDELCOs.
Old Oct 16, 2023 | 12:22 PM
miami993c297
My understanding is that DENSO was manufacturing those spark plugs for GM...maybe not!
To Spark Plugs
