BCM trouble
Old Oct 21, 2023 | 03:01 PM
ESB-LS2's Avatar
ESB-LS2
Default BCM trouble
I have my BCM with a faulty relay. I already changed the BCM 5 years ago. I live in Quebec Canada and they are discontinued. Can I change the relay and if yes where can I buy it?
Old Oct 22, 2023 | 06:08 AM
Dano523's Avatar
Dano523
Yes, mouser electronics if your taking relays on the board.
https://www.mouser.com/
Just pull the relay number, then do a quick search on mouser for needed replacement to solder the old one out,and solder the new on in.
Also to note, if problem is not the coil side, but the contact sides on the no solid state relays, then not hard to pull the caps, clean up the contact surfaces, then super glue the old cap back down.
To get the board out of the case, need to Drill out the lips of the silver grommet lips on one side, so you can push them out first, then case will open up via the tabs.
If your talking about the relays that plug into it (either top or bottom of unit), then easy to find a replacement via just the number instead.
