MAP sensor voltage range vs. vacuum
Old Oct 24, 2023 | 10:53 PM
DougHG8's Avatar
DougHG8
Default MAP sensor voltage range vs. vacuum
Does anyone know the voltage vs. vacuum data on the MAP sensor? Apparently the used set of manuals for my 2006 Z06 I bought is missing volume 3A which is where the data is I'm guessing.
Old Oct 25, 2023 | 12:30 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
This should work !!…engine off you should read about 103 KPA or 14.93 psi/ 30.41 inches of Mercury at sea level.
Old Oct 25, 2023 | 11:07 AM
DougHG8's Avatar
DougHG8
Thanks so much!!!
To MAP sensor voltage range vs. vacuum
