Fuel pressure sensor
Old Oct 27, 2023 | 08:51 PM
Moosez63's Avatar
Moosez63
1st Gear
Default Fuel pressure sensor
Need some help on how to replace the fuel pressure sensor getting code p0453 clear code with reader comes back when cranking car up
Old Oct 28, 2023 | 01:33 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The P0453 is a “circuit” code (FTP Sensor High Voltage) as opposed to a “performance” code so it can be a bad sensor or the wiring…sensor has 3 wires…a 5 volt reference, a signal, and a low reference (ECM ground)….if your code reader shows a fuel tank pressure sensor data PID you should see around 1.5 volts which is common on most GM platforms…as far as wiring it can be a broken reference ground wire, or a bad sensor…sensor accessed at the right rear tire wheelhouse panel.
