06-07 engine wire harness diagram
Old Nov 8, 2023 | 10:37 AM
curtisb23's Avatar
curtisb23
Default 06-07 engine wire harness diagram
Anyone have the pin out for the throttle body from tb to ecu ? I need to ohm out the harness I'm getting a code for it and have already replaced the plug and 10in of the wiring. Installed another tb.
Old Nov 8, 2023 | 12:43 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What’s the code ??…you normally don’t “ohm out” issues like this…resistance checks tell you NOTHING !!
Old Nov 8, 2023 | 01:13 PM
curtisb23's Avatar
curtisb23
[QUOTE=C5 Diag;1607219990]What’s the code ??…you normally don’t “ohm out” issues like this…resistance checks tell you NOTHING !![/QUOTE
ohm the wires out would tell me if there is a broken/Chaffed wire... i work on construction equipment i do this on a daily basis.
Old Nov 8, 2023 | 01:15 PM
curtisb23's Avatar
curtisb23
The codes are p2119 p2135
Old Nov 8, 2023 | 01:23 PM
C5 Diag's Avatar
C5 Diag
[QUOTE=curtisb23;1607220081]
Yes, only if the wire is broken…if chaffed almost all the way through you will still see good resistance…that chaffed wire (power or the ground)has to handle the current flow…loaded circuit testing with a headlight bulb is how to do it correctly.
Old Nov 8, 2023 | 02:07 PM
C5 Diag's Avatar
C5 Diag
Using a labscope to check the P2135 is preferred vs a DVOM to see changes in the TPS 1 and 2 signals…wiring and code description below…is this an OEM TB ??…if not this may your problem !!
Old Mar 15, 2024 | 09:41 AM
curtisb23's Avatar
curtisb23
Oe tb. I tossed on a 2nd same ****. Havnt had time to get back to this issue
To 06-07 engine wire harness diagram
