Harmonic balancer replacement cost?
Old May 19, 2024 | 07:35 PM
Mikey72's Avatar
Mikey72
5th Gear
Default Harmonic balancer wobble
Does this look like it needs replacement or is the wobble okay?
Old May 19, 2024 | 08:13 PM
Iowa's Avatar
Iowa
https://youtube.com/shorts/WMFHmplg9...pNeNYrwKU3QeXP
My 07 with 21k looks similar. Took the car to a dealer for a recall and another shop to have brake fluid flushed and asked both to look at it. Both said it's fine and just to keep an eye on it and check it every oil change. If it gets worse it's a sign it's going to fail and I'll have it swapped at that point.
Old May 21, 2024 | 10:55 AM
jonjoy's Avatar
jonjoy
Some wobble okay. Too much not okay. Most of you don't know how the thing works. Inner steel wheel with outer steel wheel bonded together with rubber it's supposed to move, that's how it "balances "
Old May 22, 2024 | 09:37 AM
65 Drivr's Avatar
65 Drivr
Originally Posted by TCW
I belong to the East Tennessee Corvette Club with over 400 members. I know of no C6 owners that have had these problems.
That being said, I don't think these problems are as wide spread as it might seem.
Tom
I have owned four C6's including my current one. My 1st one was an 08 6spd with 45k miles and had to have the clutch slave MC replaced and the headlight harness repaired under warranty. 2nd one was an 09 auto that had to have the HB done and the Cats replaced (under warranty). 3rd one was an 07 auto that had the fuel pump and gas tank elbow replaced by the PO. It also had the known trans shifting flaring issue on the 2-3 shift. My current one is an 08 auto vert with 20k miles and I replaced both rear wheel bearings due to the axle nuts not being properly torqued (known issue) and I had to replace the shifter which broke.
If I buy another C6 I will be looking for it in Tennessee!
