Speed engineering headers/x-pipe/header bolts
Do I need ceramic spark plug wires or are my factory GM wires good to go? Would adding spark plug boots help or do I need any longer plug wires with ceramics boots. I’ve heard that I should go ceramic but nobody ever mentions just doing boots. If I need longer, do I only need 10” or 12”?
Are their included zinc header bolts good for long term use? If not, should I get the 12 point ARP bolts for $50 or do I need to get the more expensive ARP studs/nuts for $121? I ask as I may take the headers out one day in the future and I am curious about re-use of the included zinc coated bolts.
Are the included standard band clamps really bad or are they good? I am trying to decide if I really need the 3” lap joint band clamps instead. I’m not buying the v-band clamps are they want $25 each. The 3” clamps are $8 each and that is more tolerable. Per their website, I need 7 since my car is not a z06.
Last question is do I need to have the axle back exhaust ceramic coated or is it only worth coating the headers and x-pipe. Summer time, the center console gets hot! I’m thinking about getting the DEI tunnel kit to help cut down on exhaust and maybe even put one of their covers on my starter as well.
We all know the old saying is “you get what you pay for” but I don’t like wasting money just for nothing. I prefer spending money in the right areas. This is why I ask what everyone else prefers.
You dont need them but it never hurts. I ran stock wires for quite awhile on my SE headers. I ended up eventually switching to the GPI wires, mainly just for cosmetics.
I reused my factory bolts with no issues. Didn't really trust the janky hardware they give you. Im sure it would work but I didnt want to take a chance.
If your going to replace anything replace these, the clamps they give you suck. I went with some offbrand from amazon with the bigger overlap and no issues at all.
I cerakoted mine the last time i had them out and it made a huge difference in engine bay temp. I may end up doing the rest of the x pipe and axleback this winter. It def helps with heat transfer and keeping it in the pipes.
Answered your questions above in red based on my own experience. Worth noting the design has changed slightly, The o2 sensor placement is a pain from what I understand now. I think @farmington might have dealt with that issue if I recall correctly. Honestly for the money I think their great. I've ran them on my car, my cousin had them on his 09, and one of my customers runs them on his 12, all are holding up great several years in. I just coated mine while i had them out just to see if it made a difference and it really helped. You wont be disappointed.
Are you @StayinStock able to confirm that it’s 7, 8 or 9 clamps? Their site says 7 for non-z06 and 9 for Z06. I thought I counted 8 but man it’s hard to tell without them being open and without anyone else’s knowledge.
can you also post what Vband’s you got from Amazon?
@StayinStock mentioned that he got 3” lap band clamps. Those are now an option to buy for $7.99 each from speed engineering. Those are what I plan to use. V-Bands cost like $25 each. I’m going to call speed engineering Monday and ask them about the quantity of clamps.
As far as the spark plug wires, that same question you have is a question I thought about as well.
Wire Length depends on your valve cover and coil placement. If your running stock location you want the smaller ones. If you're running a tall valve cover like a preform or katech you want the long ones. I've never ran boots... never had an issue on any of my LS motors.
i called speed engineering today. If you’re going to use their product from front to back, it’s 11 clamps. If you’re using their headers and x-pipe with z06 axle back, it’s 9 clamps. The x-pipe all by itself is 7 clamps without headers. It’s hard to see but once they explained, I can see 11 clamps in their pictures if your doing their headers, x-pipe and muffler kit.
looks like I am ordering 11 clamps. They said you can use OEM spark plug wires but recommend heat boots.
i hope this helps.
