Rev Matching
https://www.corvetteforum.com/forums...-overview.html
There's a video a few posts down. This is the closest you can get to the C7 rev matching with a plug and play solution.
depending on your shoe size, it may help getting a gas pedal with a slight extension, like this
https://eliteengineeringusa.com/c6-a...num-gas-pedal/
I did because my size 9 shoes, were a bit small to comfortably blip the throttle on this car, designed for huge Texans. Its perfect
Or, you can get something not quite as pretty, but even larger https://amtmotorsport.com/products/c...dal-extensions
admittedly the only car I ever drove with rev matching was a C7 Z06, and only on track, briefly, a couple of laps (student's car). I asked him to turn it off for me...but suggested he use it if he wishes. I was unaccustomed to it
Learning to heel and toe properly was critical back then, and not doing so would beget another learning experience...transmission swaps and cracking the cases open to fix them. That, and looping the car!
BTW, it may be easier to do on track, when braking harder (greater brake pedal pressure) and revs are at a higher rpm for the blip, than on street where the rate of deceleration is slower and we may only have very light pedal pressure. Depends on the car.
But there's nothing as satisfying driving a manual gearbox than perfect heel/toe down shifts through the gears. In this respect, our torque monster V8s, with their tall gearing, may even be a bit less enjoyable than some old school torqueless wonders on a backroad. We can just leave these cars in 3rd or 4th on the twisties, and rarely need WOT anyway. In this scenario, its pretty unnecessary to be rowing through the gears to keep the engine in its power band, it being so broad (I do it anyway, for the satisfaction and burbles)
So, for the past 50yrs, I automatically heel & toed on every manual transmission car I've owned (dozens)....some easier than others (pedal placement) ...as have my old GF's and wife of 39yrs. And if I could teach them to do so as a second nature, truly anyone can perfect this lost art.
I suggest anyone owning a manual try to focus on learning this as it adds immensely to the experience.
like another poster mentioned, it’s much harder in the street because of the high brake pedal position and what little pressure you’re applying. The brake sits much higher than the gas, on track it’s probably be much easier (never tried my c6 on track)
Totally agree that blipping the throttle and downshifting smooth as butter is soooo satisfying
True that, unfortunately you loose that feature as soon as you tune them. Or that is to say no tuner I'm aware of has yet to figure out a way to retain it.
pretty much... i will say though I've driven a few cars now with active rev matching and its alot of fun. Is it as fun as doing it yourself? I dunno... maybe? Either way it puts a smile on my face so does it matter how you achieve it?
