New Techm question.
Old Dec 19, 2023 | 03:29 PM
Todd Mitchell's Avatar
Todd Mitchell
Default New Techm question.
Aloha gang, I need a new trans control module for my 08 auto. Anyone able to order one with your VIN programmed in already? I see one company claiming to do this, but they haven’t returned my call yet.
thanks.
Old Dec 21, 2023 | 03:58 AM
Dano523's Avatar
Dano523
TCM is in the trans on a A6, and have not checked to see if someone local has a tech 2 clone and TIS200 to flash the module in, once installed?
Hell, to back it up, if you are wrenching on the car yourself, then should have your own a tech 2 clone to start with. Hence to power flush the brakes, need to cycle the ABS pump, so having the tool for this is needed from the start as well.
Old Dec 21, 2023 | 05:41 AM
Todd Mitchell
Yah, I’m doing the work. I’ve done the valve boby and techm switch seals before. I have hp tuners and tune my own car. It has trans relearn. But from what I understand, I still need the tech 2 clone. I suppose I’ll research buying a clone. Thanks.
To New Techm question.
