I'm in the UK and recently fitted Infirai tail lights as I need orange turn signals here. They've been doing some strange things so I went to clean the main tail light harness connector. Well, that's my problem. It's badly corroded and some of the pins are hardly there. I can get a new tail light harness but it's 07 on. The pigtail adaptor is #88988066. It would be great getting the new harness anyway as the previous owner spliced the wires horribly to get a work around for the turn signals. My issue is the male side with the pins is on the car body harness. Can I get this pigtail somewhere? Could I skip the pigtail adapter and splice the 07 on male harness plug to my car and then plug the tail light harness in? Does anyone have a wiring diagram, I could even just solder on the tail light harness to the car loom?
Can probably clean the connectors and contacts with crc electronic cleaner. I have used it for numerous electrical stuff and it works well
Any auto store sells it...
Thanks for the help chaps! I bought a new Delphi GT150 connector and a new harness, they just arrived from USA. I'll swap the harness out and change the connector and update you
Hey man did this work for you? Have the exact same problem with my morimoto.
Hey yeah it worked fine. Sometimes I would get hyper flashing but it would tend to be the tail light where it plugged in the harness. I just plugged/unplugged them and it would sort it out
