C6 Running Rich?
When hard accelerating I notice a burn smell, it goes away when casual cruising. I read somewhere that it can be a rich fuel mixture. If so, what can lead it to running rich?
So car running slightly richer than 14.7afr at WOT throttle, the norm (about 13.9FR).
Running way rich at WOT, with say under 13.5 AFR, could be the car was after market turned to run this much richer to make more power, or air filter is clogged, and why it running that much richer at WOT instead.
So real question, is smell like unburnt petrol, or more like rubber instead.
If rubber, could be belt slipping, or even coupler in the TT going out, and smelling it rubbing on the inside or the TT,
https://preview.redd.it/blown-out-to...=webp&d619e405
